Jahay
02.15.2011, 06:53 AM
Ok bud...
GREAT NEWS
the vorza cup is a PERFECT fit for the LST2 CVD
I thought i would take some pics for you just in case...
Looks as if it would fit perfectly in this image below. OC next to it is the SHD savage cup.
The fit in the cup... There is no side ways or any movement for that matter. It is a perfect fit.
So linc, as you made your braces around the savage X cup, what does that mean? does that mean you made the braces a little too long? have you got any images of it mocked up completely and can you show the problem? i didnt think it would make much of a difference if you mocked everything up using the stock x OC or the LST OC?
As i know that the vorza cups work, i am going to rebuild my vorza diffs with teh vorza OC now and make sure everything is shimmed right in the GH Bulk... hopefully no shimming is required...
