fiero_silva
03.13.2006, 01:24 PM
it is going to hard to work two mounts in one. The lehner 22 seris has different mounting holes. I use two. If you make the holes reall long you can put three in it and run in the same as the xl motors.
Not really that hard... The lehner has a 30mm bolt circle, the XLs have a 25mm bolt circle.. Just stagger them like so:
This mount isn't complete, I have to add threaded holes for the mount to attach to the Savage's motor plate. It will fit 22 Series Lehner's and 540 size Feigao and Wanderer's. With the 22 Series Lehner being the largest diameter motor the lower heatsink will just be touching the motor.
The inner 4 bolt holes are for a 540 motor. The outer 4 holes are for the 22 Series. The most outward cutouts are for reduced weight/motor cooling/good looks :)
I may add a mount for a fan, as well as a rear stabilizer bar for the motor (this bar would screw to the mount as it would have to be different for the different dia motors.
