candy76man
02.15.2011, 02:59 PM
Well, I got the kershaw axles today and got those installed so at this point I basicly just have to put the truck back together and I should be good to go
The longer rear dogbone fit fine but I did have to drill a new pin hole on the front tranny output and cut off about a 1/4 inch of it but thats all it took...I now have about 1/4 inch of play on front and rear dogbones which I think is enough to prevent any binding when the chassis flex's...besides most of the flexing it does actually opens up the gap rather than closing it so it should be fine.
I put a few o rings under the ends of the dogbones on each side to keep them centered and prevent them from sliding back and forth all the time....Any reason that may not be a good idea? They can still move back and forth, just not without a little pressure.
Is it normal for these lst diffs to be a little notchy when new? (I mean the ring and pinion, not the diff itself) One is fairly smooth but the other is pretty notchy, I assume they will wear in and I don't see any way to adjust the mesh aside from the one shim on each one and thats already on the side that opens up the mesh slightly.
heres a pic of where I'm at
