Gustav
Gustav's Avatar
03.13.2006, 02:00 PM
There is one problem before your design gets made. It won't fit a 22 seris motor
The bolts are not straight across from one another. So you need to change it a little.
How many holes on the 22 series coolhand?The 19 series has 8 so the 4 bolt pattern would work there.
Edit: the BK site shows 8 holes for the 22 series so the the design should work as it is.
@fiero silva,just an idea for the rear support,how about making a circular rear support as one piece with the mount and then use a reducer for the 36mm diameter motors.
