The Overclocker
The Overclocker's Avatar
02.16.2011, 01:12 AM
I think the biggest suprise is going to be the fact that play time is going to be limited while waiting for everything to cool down when geared so high. 30min runtime is no problem when you count the 5 min of cool down time after 2 minutes of running. Get a big motor if you're going to keep it geared high all the time. 1717 or a 1527 have alot more torque to pull that kind of gearing and won't heat up as fast.
wont fit
thats why i chosed the 1515
the ve8 has maximum 76mm clearence , or else it rub's on the steering post
