02.17.2011, 02:01 AM
Originally Posted by J57ltr View Post
Linc have you fired up that beast yet?
I have not, still waiting on the endmill so I can "properly" mod the other hub carrier.
I also found some more cvd drive cups and may use them instead of the revo ones I had laying around. We shall see. Still thinking 71 or 72mm would do.
Now keep in mind if you plan to do that and want to keep the stock rear wheels and do not have the lst driveshafts, you can use old maxx cvds (for the 2.5 tmaxx or 3906 emaxx) and they have the correct length axles to use the stock pede 4x4 rear wheels.
I am using the lst axles casue my pede 4x4 came as a chassis and I robbed the wheels off 2 of my other pedes, and would like to put one of them back together.
If you buy the same ebay brand maxx cvds off ebay the lst axles wil also fit. So you could swap them out and use either wheel, or run the lst axles and stock wheels for a 8mm track width increase per side.
