Originally Posted by The Overclocker
i think im going to end up buying the mmm 2650kv kit , 26t pinion 44t spur and thats it ... its gething to complicated
If you look at it like all this stuff that needs to be done at once it will seem overwhelming. Look at it more like a process and progression. Start out with the 26T pinion and 44T spur, and see how fast it goes. Run it like that and get some practice driving it. Then a little at a time you can start modifying, upgrading, customizing. Try do make it so each thing you do gives you some type of quantifiable improvement (even just 1-2mph, or a little easier to drive). Doesn't have to be major things, maybe just a different set of springs or different wing angle. Over time you can build the ultimate speed machine. But it won't happen overnight.
