fiero_silva
03.13.2006, 04:50 PM
Originally Posted by Gustav
So the whole mount will slide to set the mesh?
EXACTLY!.. It will mesh the exact same way the Nitro Savage motor mount does.
There is one problem before your design gets made. It won't fit a 22 seris motor
The bolts are not straight across from one another. So you need to change it a little.
That will be an easy fix.. I just need to know the exact orientation of the holes.
What you mean? It is a 30 mm around. I don't know if all the motors are like mine. I would assume so.
BK's site shows 8 holes evenly spaced on a 30mm circle for the 22 Series.. That's what I designed for.
How many holes on the 22 series coolhand?The 19 series has 8 so the 4 bolt pattern would work there.
Edit: the BK site shows 8 holes for the 22 series so the the design should work as it is.
@fiero silva,just an idea for the rear support,how about making a circular rear support as one piece with the mount and then use a reducer for the 36mm diameter motors.
If the 19 Series has 8 holes on a 30mm circle that motor will bolt to this mount too. Bonus! :)
Perhaps the BK site is wrong with the 8 holes.. I had looked last night and found some sites that pictured 9 holes and others that showed 8... Can anyone confirm the number of holes and if they are evenly spaced?
I like the reducer idea, saves material and time.. Just use a set screw or somthing to hold it in..
