02.18.2011, 08:44 PM
Well the lst cvds I am modding are the same size as the X dogbones. So the teknos should be fine, as long as the cups on the axles are up to the task and do not wear or shatter.
I know lst cvds are good, I have run those alot, in much heavier trucks with more power. Never broke one, or wore the axles out, they are very hard material. I have worn pins and eventually the cvd shaft, but that was cause the pin wore out and caused alot of slop. The cup looked like new, the holes for the pin did not wear. I was impressed.
