02.20.2011, 04:00 AM
Originally Posted by josh9mille View Post
There are 2 things that are guanteed to happen when I watch a Sqirrel vid, and thats either I am going to fall asleep or I laugh my ass off.
Yeah, I find them amusing till he gets something way wrong, or leaves out a vital step that will really throw a noob for a loop... Noobs consider him a pro... That can lead to all kinds of issues.
Originally Posted by _dV View Post
I use blutac to balance my wheels. I just take a dogbone out, spin the wheel, see which part sits at the bottom and counter balance with blutac until that part of the wheel doesn't sit at the bottom anymore. Very easy to do and I've never had a piece of blutac come loose. Definitely worth doing.
I have had wheels (MT and larger) that required 1/8 of an ounce to get balanced well, and lead is the smallest way to get that weight on. Plus the lead wheel weights with the sticky back are very easy to use.
Originally Posted by mothman View Post
Linc, so what is the best putty money can buy? really interested to try this tire balancing.
I use the lead wheel weights for full size cars. They come in strips, broken up in 1/4oz increments. I usually cut those 1/4 oz segments into 4, and start with one of those across from the heavy side. When I am finished I use some hot glue to really hold the weight on. I have not had any come off. I also clean/degrease the inside of the wheel, and scuffing the plastic will not hurt either.
Originally Posted by ljoncp View Post
Squirrel somehow manages to make every video, no matter how simple the topic, last 10 minutes or more.
And then he makes a part 2
+1
Yeah, I will setup the flip recorder my wife got for our baby when I balance the next set.
