Jahay
02.20.2011, 07:53 AM
im running a 1520 sparky
Some Updates & Images and progress
Centre diff/mech brakes and motor relocation
I had to put the centre diff and motor relocation on hold just for an extremely short while. I cannot use my existing TVPs as the 4mm alloy plates are causing problems while mounting.
I have chopped and drilled to many holes in my TVPs that they seem a little weaker.
I got two side plates made up which will go over the existing tvps...
They will be anodised in black so you should hardly notice them. And considering the lipo boxes cover them basically, they will not really be noticed.
Having these new plates, means i can now remount all my internals exactly how i want them and wont be limited to where i am available to mount them.
Next update
LST HUB MOD
I am working out and currently doing an LST 2 Hub conversion.
Everyone knows that the Savage Hubs are at very best OK. The two bearing setup is weak ....
The LST conversion offers the possibility of running 3-4 bearings per hub!
Offers increased width without the need for extenders.
The Use of CVDs (no more shafts popping out of axles)
In order to get the lst hubs to fit the savage arms, only minor sanding of the hubs were required luckily!
To get the CVDs to work with the diff... i am using vorza diff axles
some pictures of me mocking up the hubs...
Note where the hinge pin is in the pic below
The hinge pin needs to sit as close to the bulk as possible to allow correct distance for CVD to work
I measured this to 6.5mm wider than stock
Increased width over stock
And the bulk braces being made up.
2x 4mm thick 7075alloy and 2x 5mm thick 7075alloy
The lack of bulk support shouldnt weaken the system as the braces are now thicker and made from much tougher alloy.
Attempt at Bulletproofing my diffs more.
You can find the build for my BP Diffs here...
I basically used an entire HPI Vorza Diff but used the Savage BP Ring and Pinion.
Means you can use 2x 8x16x5mm bearings.
Stronger, thicker hardened internals.
Shorter axles to work with LST CVDs
Loads of comparison pics etc...
Page 1 of rebuild - http://www.rc-monster.com/forum/show...9&postcount=74
Page 2 of rebuild - http://www.rc-monster.com/forum/show...0&postcount=75
