02.20.2011, 05:21 PM
So you are geared for around 60mph. A 17t pinion is 3 teeth more than the 14 and will add quite a bit of speed. You can try, but I would be very careful and temp your batteries, motor and esc alot on the 1st few runs. This will be a hot setup, but depending on outside temps you may be alright.
This setup would not survive the southern summers, 90+f temps and 100%+ humidity make air cooling a waste of time.
