02.21.2011, 02:26 PM
I had a look in the certifit catalog and your fender new is 40 bucks, or less. It would have to be painted.
Looking at the damage I would charge you about 400 bucks for the whole repair, with a new fender. I am sure you can find a local body shop that can cut you a deal. Make sure you say you are paying cash and do not mind an aftermarket fender.
Now if you can find the part with the correct paint on it, used, that will save alot.
And changing the fender is pretty easy (said by a guy who has done it for 18yrs...). Getting the plastic clips out is the worst part, there will only be 10 or so 10mm head bolts.
