padrino
hmmm...
02.21.2011, 07:13 PM
I'm on travel so I can't post the graphs but I'm seeing spikes above 200A consistently. I'm running a 5T (many aluminum goodies) with Thunder Power 50C batteries.
One question I did have was the sample rate, I assume all of the samples are point in time so the system simply does a read on the tick it should. I set the rate at the highest (100ms) to make sure I had the greatest chance of catching things but even paring down the values recorded still only results in ~8m of log time. Based on my work on programmable circuits I assume it's done this way given basic constructs however I wanted to mention it in case I'm off base.
