simplechamp
simplechamp's Avatar
02.21.2011, 08:23 PM
Originally Posted by bundyracer1 View Post
wat lol im not changing the motor mount i was thinking of just turning the whole centre diff but i dont think it will work anyway my motors long. yeah kieren did all the wiring
I have the diff flipped around like that in my Jammin. Yes, the longer length 70-75mm motors are too long, you would need a more typical "buggy" sized motor, like 60-65mm. Aside from that you might need to put shims under the center diff mounts to add some clearance, as the spur will no longer be over the clearance hole cut in the chassis.
Honestly, I can't say how this setup compares to a single pack setup like you have it now, because both my buggy and truggy have always been saddle pack with the diff flipped around. But I have noticed a lot more vehicles using this setup now (Nexx8, Durango, Caster, HHH chassis for Hotbodies)
