02.23.2011, 11:20 AM
The new era are the best, hands down. I run the stock plactic c hubs and new era spindles. Never had a breakage, and if I really hit something hard the plastic c hub will be my break point, as it is cheap and easy to replace. I was breaking the plastic spindles where the steering tierod mounts.
And the difference between the lst1 and 2 is mainly the bearing sizes, the lst1 has 6mm axles and the inner and outer bearings are the same size, not so with the lst2.
