Originally Posted by Jahay
i googled absolutley everywhere with no luck!!! seems out of stock and discontinued...
That cen pin is only 3mm.. .it may cause play in the hub?
The hub end pin is only 3mm, but the bulk end pin is 4mm.
p/n is gs025, and you will use a m4 thread nyloc nut to retain it. Much better than e clips.
http://www.cenracingdirect.com/index...ROD&ProdID=288
The listed specs are 4x56 but the extra length is the threads. I can take a pic for you of this pin installed in the lst hub...
