02.25.2011, 01:32 AM
Originally Posted by J57ltr View Post
Believe me if you saw half the ghetto stuff I have to do. I am in the middle of R&D on a new scale and I have 2 precision blocks welded to a 3/8" thick plate. I had our welder make it for me and he just tacked it in place. One was about .5* off and I had to cut and tack it back in place then weld it across to make it stronger but when I did, everything shifted on me (as SST does). So I had to use a precision hammer to beat it back into place, precisely. So no I wouldn't not laugh.
Let me know I'll cut you some blocks of Delrin in the morning. I have some that is 2" thick and is flat top and bottom. I also have 1" thick and some other sizes.
Jeff
2" would be good, as it would clear the vise I have and allow me to eyeball stuff (my precision instrument) a bit better.
And these hub carrier are actually the same as the nitro rustler/pede, a little different from the elctric 2wd rusty/pede models. 1952 is a very old traxxas number, looked funny when I 1st saw it!!
