johnrobholmes
johnrobholmes's Avatar
02.25.2011, 11:40 AM
Just figured I would comment here.
The only parts that are shared with the sidewinder and the TM controller is the plastic case. The board was custom made for me and the design is new (as of two years ago when we designed it).
6s 80a overkill for most crawlers? Yes it is, but overkill is not always a bad thing. 5a BEC enough for most crawlers? Yes it is, unless you are competing and are using over a 300 ounce inch servo or need to turn up the BEC voltage.
We will be adding some new features to the firmware as time goes on as well, ones that will really add features that crawlers and offroad bashers need. This controller is specifically designed for total motor control, and recently we have been installing quite a few units into battle bots as well since the features really work well for them.
Beyond that, a new controller that is smaller is being developed as well. But all the software features will port over.
---JRH---
