nascarfan3199
02.25.2011, 04:21 PM
Are the mounting holes for the motor mount in the chassis slotted? If they are, as simple as that mount is I would cut my own out of a peice of alum. angle and then tap the hole in the mount so you can you a flat head screw so its flush with the chassis. They way it is now works but I think if you will be running on pavement before you know it the nuts will be ground down to nothing.
