mrsnuggles
02.25.2011, 09:46 PM
Originally Posted by Knez View Post
I also doubt that he would be a copy-cat
Alza Baja kit is a lot better than tcs kit, more settings and options also a lot better weight distribution and easy to maintain as servo plate is not as big as HPI box so makes things easier, at least aproach to the steering kit.
Well there is like 158mm or maybe 159mm room.
i personally use HK 5000mAh 3S 40C/50C lipos so ther eis a space for a "foam" so lipos get protected a bit...
Do u mean my signature or the link that i provided or that Desertboy XL signature in the picture or all this ?
And here a pic, that slipped...
HPI A720 shocks with pink + yellow springs vs "down" HPI stock
For heavy loaded trucks..
Knez
actually he is a copy cat. he just copyed my product, bashcatrc bulkhead braces, he just made some tweaks to the design. one piece was even a direct copy, but i got him to change the design enough so that it would not be mistaken as mine.
it really sucks to have worked hard on coming up with solutions for problems that the original design has, and having some guy with a cnc machine ripping your design off.
just wanted to let you know what this guy is all about.
