FG101C
02.26.2011, 02:41 PM
The pack will end up with two deans, so I figure it will be charged as two separate 3s packs in Sync mode on my duo charger. What I'm saying is for some reason they put a 4s tap on one set of balance wires instead of a 3s tap. My plan is to replace the one with a Hyperion tap, that will also distinguish between the two so I plug in everything correctly when it's time to charge.
Guess I should have just went with the hobbysh!@tty nanotech pack, but I do need something to do today.
