Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.26.2011, 08:52 PM
OK, just got some parts in.
I have a pretty much off the shelf cvd option here. It does require bearings with a 6mm inner, so either go with a 6x11 as a drop in replacement, or enlarge the hub carrier to fit a 6x12.
Using these parts:
HPI 80853 70mm savvy center driveshaft (made by mip)
Mip 1488 tmaxx axle
Mip 1147 rebuild kit
stock hex drilled to 6mm inner or the tekno 12mm hex for 6mm axle?
stock tmaxx wheel drive pin trimmed slightly or a shorter pin?
revo diff outputs (drop in fit for the stampy diff, with 6mm outputs)
6mm bore drivecups, long length (will need some help identifying these)
So you end up with a seriously stong 1/8 scale size mip rear cvd setup, larger 6x12 bearings and 6mm outputs in the diff.
You are all welcome.
Pics to follow.
Where are these pic's Pimple ?
