Thread: Castle 1410 1y
scarletboa
scarletboa's Avatar
02.27.2011, 08:13 PM
you should be fine then. it should run pretty good actually. i was expecting a lot out of the 1410 motor, considering it is based off the neu design and not only has it met my expectations, it has surprisingly exceeded them. this motor is about equivalent to a medusa 60mm motor as far as power handling. i would be shocked if you could even get that motor over 150F in that buggy, and that's without the blower.
