Thread: 12020 question
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
03.14.2006, 06:21 PM
Originally Posted by damon
I am installing at 12020, UBEC with plans for an 8XL when they are in stock.
Set up thus far: MIP CVD, Steel Idler Gear, Strobe Slipper, Power stroke Shocks - other wise a stock E-Maxx including radio and receiver. 12-14 cells.
questions:
I found the receiver pack jumper, but I can not find the BEC jumper. The info I have says it is behing the reciver jumper, but I can't find it. Do I need to trim back the shrink wrap? Where is it located? Will the void the warrantee?
What is the purpose of the receiver pack? Is it needed?
Will this work with the stock radio system?
Thanks!
The BEC jumper is black. I'm thinking you have found the BEC Jumper, and think it is something else. Like Coolhand said, there is only 2 jumpers on the Warrior controllers. If you have removed the black one, then you have disabled the BEC, so you will need to use a reciever pack or a UBEC. Here is about where the Black Jumper is on the underside of my 9920:
The purpose of the Reciever pack is to power the servos and ESC when there are too many or too few cells for the ESC to make 6v for the servos. The reciever pack is just a UBEC, only you have to charge it every-once-in-a-while.
Hope this helps,
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
