03.02.2011, 05:36 PM
The 50hz will let you capture higher watt+amp peaks and voltage dips. I was able to see the Acepow pack drop to 8 something volt under load for 0.002 of second. This was enough to disable the RX8 ESC as the voltage cutoff was enabled. I wasn't able to see this with my older 10hz version.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
