Originally Posted by BrianG
Sounds to me that the ESC is a bit underpowered for the application. But a 2WD pede geared for 40 shouldn't be that hard on an ESC unless you were doing lots of stops and WOT starts. Maybe something IS wrong (at least partially) with the ESC after all?
You could try a MM just to see. I know you have at least 2.
I was thinking just that. The esc temped around 135, but those heatsinks are hard to get a good reading from. It was way to hot to hold a finger on. I may try a MM and send the sidewinder back to cc to inspect. Should still be in the warranty period.
Others are having good success with setups that should draw more load than this...
