thzero
03.05.2011, 12:57 PM
Um, no. The more teeth you add to the pinion, the higher the gear ratio (numerically its lower), and the higher the gear ratio the faster you go.
Originally Posted by rcBOB View Post
Thank you thzero, i tried the speed calculator but there is a problem :
the mph increase as i increase the number of teeth of the pinion (motor).
Is that a bug ??
