03.06.2011, 02:41 PM
EDIT: Is it OK to use the CC BEC with the AC adapter as input rather than a battery?
Only if the output of the AC adapter is DC (some output AC). Also for better results, you may want to add ~1,000uF or more of capacitance between the adapter and BEC. Doesn't have to be low-ESR and should be rated for 25-50% more voltage than you plan to use. For 6v, 10v caps are ok.
