Overdriven
Destroyer of Tires
Overdriven's Avatar
03.06.2011, 10:20 PM
Originally Posted by brian015 View Post
I think Overdriven is saying to drill a new 3mm hole in the Baja hex - not your axle.
That's exactly what I meant.
Originally Posted by thzero View Post
AH yes, good point about drilling a new hole in the hub. Had been approaching from the other direction.
Well that may be true, but what holds the hub onto the axle laterally?
The pin - but in my experience, impacts that would pull the wheel off sideways are rare (depending on how you drive, I guess!).
You're more likely to encounter significant forces that are trying to push the adapter onto the axle rather than pull it off. If you look at the diameter of the adapter itself, theres quite a bit of thickness there that the pin would have to rip through to get it off. I'm not saying its impossible to do, but it would take some doing.
