Scoob
Scoob's Avatar
03.15.2006, 08:20 AM
I used to be the worst at soldering and I hated it but I finally got it and am pretty decent now. I don't know how much it will help you but the single biggest help for me was using a wet sponge to clean the tip. My tips always got to the point where they would not heat the solder and when it did the solder would just fall off the tip. Cleaning the tip took care of both of these problems. Every couple minutes clean the tip and you can get alot of the black off. It seems like my tips always have to "break in" before they'll transfer heat worth a darn. I don't use the pointy part of the tip, back away from it a little and look for the shiny part to tranfer heat best.
