On asphalt it does have a tendency to roll over in sharp cornering. But I attribute that to the higher CoG on both the TVP design, the higher placement of the motor in the Flux TVP design, and the batteries being over the driveshaft, and a bit with the width of the truck even with XL axles.
Offroad I've really had no issues.
Originally Posted by Jahay
Also with your experience with your tyres, how have you found them in corners? do they slide a little or is there so much side bite that they grip and force you to roll over?
