03.13.2011, 04:23 AM
Originally Posted by ta_man View Post
So long as you use mechanical brakes and don't get any stones in the pinion/spur interface, you might be OK. But I think you are lilely to snap the 1/8" shaft clean off if you use it with electric motor brakes on a 1/8th buggy.
The good news is that Castle is supposed to be working on 5MM shaft rotors for the SCT motors, so when you snap your 1/8" shaft, you will be able to buy a 5MM shaft.
I snapped a few hacker 1/8 shafts in 8th scale buggies back in the day. 5mm shaft is mandatory unless you have a slipper setup. Even then, it is just good sense.
