03.14.2011, 10:20 AM
Yeah, no typo, I suggested 100k. If you are going to be running on-road and don't want to be shredding your front tires you'll want some pretty thick oil.
Remember that there is going to be give and take here. If you set up the diffs oils totally for on-road, you will lose some of the off-road handling and performance. If you set up for off-road you may be shredding front tires from unloading the center diff to the front when you hit the pavement.
If you want to try an "in-between" setup go for maybe 30-50k in the center.
