scarletboa
scarletboa's Avatar
03.17.2011, 11:23 PM
That may work, but I doubt it. Most chargers I've seen don't have a static output PS, but rather a "tracking output" that is just a little higher than the battery needs. This boosts efficiency a great deal, but involves a lot more modding than just popping it in there.
The superbrain charger has an external power supply with 4mm bullet outputs I believe. The hobbyking Eco 6-10 charger's input wires have alligator clips that have 4mm bullet inputs, so you would not even have to do any soldering to use your current power supply with it. If I were in your situation I would get the Eco 6-10 charger and just use your current power supply with it. For charging 2 batteries at the same time, just get a second charger and either a new power supply or make a parallel adapter so u can run both chargers off the one power supply.
