03.18.2011, 07:18 PM
Nope, picked up a MMpro and a 6900kv 36 series castle motor. Used for 100 bucks.
The 6900kv motor may get used in something on 2s, not sure. The mmpro will go in the pede 4x4 with some sort of motor, maybe the 3800 if it works. I would like to try a 1415 2400 motor in something, but doubt I will get on until they make a 5mm shaft available. I would like a lower kv 1406, or even a 1403 motor. Good for on road 10th stuff.
The front cvds should be done next week. Need to pull the ft diff to put revo outputs on it, and cut/reweld the cvds to the correct length. The aveox on 4s is just too much. Maybe try 3s with it? I can turn the puch control to 90% and maybe tone it down a bit. I have a buggy coming that could use the motor and lipo, with a hw 80 esc I have laying around. Maybe make a sc truck out of it?
