ok cool
but even on my scope i MYSELF show no positive voltage peaks or spike even under full 100% breaking force.
but Even going by all the chatter on this EVEN if it does the voltage is VERY little back to the battery and if a lipo can only take a 14v @ 5c Max charge rate or 2.2 amps ......
and the Motor under breaking puts out lets say 31v @ 10amps for that time just were do you think that is all going?????
that Aint dumping into the battery over 97% is shunted to ground otherwise the battery life would be very short and would mess up the ballance up quite badly.
so in going just by this alone would make the regernerative breaking conversation Moot for rc cars as the regernerative breaking power Back to the batteries would not charge them Enough to even consider being a regernerative system........
and yes i only run 4s on the Xerun 80A
and a 2230Kv motor
and yes paralyzed if we get more rain here as we did yesterday you will have your "puddle skipping" video but you wont see smoke like your hoping for. as the esc has been tested under water a few times now
