Originally Posted by killajb
4wd with an aluminum(guessing based on pics) chassis is a lot for that spur gear to deal with.
I think geared low enough, it would stand up to a basic brushless setup with adjusted punch turned all the way down. If there was some way to mod a slipper into that spur gear, I'd be willing to think it could take normal speeds for that chassis to keep up with the other 4wd short course trucks.
the spur gear is 32p just like a e-maxx or e-revo. it should hold up just fine as long as the mesh is good. also, they are only $3-4 to change if it strips.
i think it will handle a 1/10 brushless system or even a mild 1/8 system without any problems.
