Thomas Porfert
Thomas Porfert's Avatar
03.24.2011, 03:57 PM
Double check on the Castle Link and see what the LVC is set for. Is it on Auto-LiPo or do you have it on a custom cut-off (IE 20.4V for a 6s?) How many cells are you running? If you do have on Auto-LiPo, when you turn on the ESC listen the to noises that it makes. The first chime is the initialization, then there will be a number of single beeps, that's the Auto-LiPo cell count. Make sure the number of beeps matches the number of LiPo cells.
Are you getting steering control? What happens if you unplug the ESC from the receiver and power it up, is it still the yellow and green flashing?
Thomas Porfert
Tech Support
