Your right about that. -
03.26.2011, 02:08 PM
Yea your right about that. Making it voluntary allows it to look as if our Gov is not trying to scare or panic anyone by making it manditory. Still in any situation such as this one if it looks even remotely serious and has the potential to become in any way life threatening I would not wait for any Gov to tell me that things are worse and that now I have to leave. If even a hint of trouble shows, and they offer to pay your way out, then you are a fool if you do not leave.
We all know that local Gov lie just to keep from panicing its people and also covering its own a$$. There is always hope for a resolution, but I would have to go on the side of caution when lives are at stake. I am sure that most of the people around the world are hoping that Japan gets things under control and that it will not end up contaminating other countries by accident. Still I have to think that there is an awful lot of ground to cover on their part before this looks even remotely under control and we can all feel safe from danger. With the predictions of this looking like it may takes months or even years to contain and clean up I would have had something more perminant cooling wise set in place by now. They could easily build some water cannon stands around the complex with huge portable pumps in place that are capable of spraying a very large amount of water on these reactors to keep them under the temp limits that make them so dangerous. Once that is in place then begin formulating a plan to go in and recover regular cooling systems at least to the point of relieving some level or pressure from this whole situation.
The other problem with spraying so much water on this mess is that the water becomes contaminated itself, and where do you think it is going? Yea that's right, probably right into the Ocean contaminating all of the sea life in the area. And there is no way to control that. Once its in the sea it will travel everywhere over time. Before this is over with the entire planets Oceans will have a higher radiation level. This may very well become a global seafood catastrophy.
