Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
03.26.2011, 11:29 PM
A mesh that is too tight can overheat metal spurs & pinions as well. How do you set your mesh? Can you hold the pinion and then rotate the spur ever so slightly, and I mean slightly? If there is no movement at all, your mesh is too tight.
-Chad
PM ME IF YOU HAVE THE BELOW:
