BIG-block
03.28.2011, 08:52 AM
What charger are you using Jerry? Most chargers these days can take more than 12V and all the big power chargers need at least 24V. The PowerLab8 will not be able to charge at much more than 500W with only a 12V input regardless of the current that that the PSU can supply. In fact the PowerLab8 can handle up to 32V.
For you if you have a high end charger you are better off getting something like this PSU. CLICK HERE Mean Well have a pretty solid reputation from what I can gather reading the net. Also the unit in the link is switchable between 120V and 240V AC so you should be able to take it anywhere around the world.
I am leaning towards this unit. CLICK HERE. It should be a pretty close match for the PowerLab8. The only thing about it is that it isn't meant to operate below 180V AC so it wont be much use to you guys in US. For me it will be perfect.
