Nixpus
03.29.2011, 07:38 AM
More or less ending up in a G-Maxx layout I think... Question is if I should keep the cut out and try to get the bats as close to the dogbone as possible or simply use the TVPs as sidewall in the battery "tray". Having the bats outside would leave plenty of room for the wires ;)
Cut out placement:
Bats outside TVPs:
Pretty low CoG:
Skidplate mounting to the front bulkhead. Using the 4 existing screws in that area. Just swapping them to slightly longer counter sunk screws. the rear will bolt with 4 screws into the CD mount (CD mount will bolt into TVPs with 8 screws)
Expecting to use 3mm alu for the skidplate and trim TVPs/skid as best I can to loose weight at a later time.
ID:	9850   Click image for larger version
ID:	9851   Click image for larger version
