Thanks for everyone chiming in asap
Brian, i havent used that calculator. Pretty kl tool!!! BUT it wont let me choose speeds of higher than 50mph and it wont let me choose up to 50V of power.....
Linc, i think you may be right regarding the motor... And due to my current gearing difficulties using a pinion which is too small.. the 1527 925kv would be ideal as it lets me use a larger pinion...
Differential Ratio: 3.2222222222222223 -
Savage BP Diffs
Transmission Ratio: 1 - Centre diff
Other Ratio: 1
Spur Tooth Count: 47
Pinion Tooth Count: 15
Total Voltage: 44.40 -
12s @ 3.7v
Motor KV: 925 -
Neu 1527 2.5d
Tire Diameter (inches): 6.88 -
Baja bow ties
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.13 : 1
Total Ratio: 10.0963 : 1
Tire Circumference (inches): 21.61 inches (549 mm)
Rollout: 2.14:1
Total Motor Speed: 41070 RPM
Vehicle Speed:
83.26 mph (133.74 km/h) -
Effective KV Value: 925
KT constant: 1.46 oz-in/A
I believe this should be achievable with my 18-20lbs savage. Considering there is a guy on here running a baja 5t weight 29lbs on 12s geared for 80mph without any heat problems at all....
BUT on a side note... i am not sure if i want to spend $300 just yet on a setup i am not sure i will like
Are there any cheaper motors i could try which are of a lower price before i drop serious coin? Could i just look for most motors around the 900-1000kv range?
What would you recommend? anything from hobbyking i could try out?etc...
