Jahay
03.30.2011, 07:06 AM
That very true bud...
Considering what you have said, i took a close look at the hubs and bearings...
There is around 4mm of play for the 3rd centre bearing.
I will make a 12x16x4mm spacer made up which will push the 3rd bearing towards the shaft supporting the load on the larger,weaker 22mm bearing.
Hopefully this should help take a little stress from the heavy baja wheels... If it works, then awesome, if it doesnt, then its all good anyway...
Just wondering... is it possible to get custom bearings made up?
Because it would be nice to have a 8x16x8mm bearing as the third bearing....???
