Nixpus
03.30.2011, 11:00 AM
Seems like we need to push the rear bearing a bit back - 1mm should do.
Might have to push the whole front a bit. That dogbone has a fair bit of play!
In the front we need to adjust the opposite way... fun :)
We also need to shave off a good bit of material... because as it is we have 2° steering throw in both directions... we need as much as the standard setup and then some!
This is where the pin hole should be positioned.
ID:	9856   Click image for larger version
ID:	9857   Click image for larger version
