03.31.2011, 11:19 PM
Some good lst info for your build, which is great!!!
If you want to move the cd forward to cut down on the ft shaft length you can use a lst1 wheel cvd shaft, it will fit the cv end that attaches to the rear diff.
I would suggest using the HD cups with al diff cases. Or try to scare up some nova rc al diff cups. The hd cups work very well. They will not explode like the center cup did!
Build looks great. I happen to have a section of al channel I purchased a few years ago to make a buggy out of lst/muggy parts. I planned to use a xlb body I have, so it would not be 1/5th scale, more like 7th scale.
Looking good, keep up the great work!
