brian015
brian015's Avatar
04.02.2011, 07:35 AM
Originally Posted by Candyman2 View Post
THAT is right yes, its stronger as in , if you try to bend it, but NOT for torsional rigidity, i.e if you twist it as in a propshaft. A tube wont twist under a load where as a rod of the same diameter, like in this particular application, will. Im not a mechanical engineer, but it has to do with it having twice the surface area, inside and outside rather than a bar only having 1.
So please back that claim up with some evidence.
