zueslilbuddy
zueslilbuddy's Avatar
04.02.2011, 11:08 PM
Originally Posted by v8hatch View Post
WOW your going with a bit of bling i see, looks good.
Was it sitting a bit high up the front? if so you could put some "O" rings on the shock shaft on the inside to shorten it a bit, that's what i did.
Na it was sitting with rear just a bit higher before bit i wanted to use the Shocks and arms I had on my XXLST-2, they were causing a problem with the muggy shock tower
The other thing i noticed is you don't have the muggy block that sits in the bottom a-arm that sits the shock out fourther towards the wheel.
Well it did have them before the aluminum arms and LST-2 shocks, My XXLST is going to get Muggafied with the parts I took off of the project and the blocks will be used on it.
My XXLST-2 is my speed demon monster truck lol
