Candyman2
Candyman2's Avatar
04.07.2011, 02:56 PM
Right plan is to get the electronics flat in the chassis, get the lipo flat and put the motor further back. Also fitting a proper 1/8th center diff and regular plastic 46T spur. Also not happy with the braces to stiffen the chassis, if you really get hold of it it just flexes where the braces meet the chassis and I want it stiffer than that.
Cut a chassis plate out 10mm longer than original (that is rc-monsters extended chassis) and made the basic diff/ motor mount.
made the rough diff mount for the other side and had a trial fit of stuff
needed a new top "deck" for my new brace
Might be better to have the receiver on the right.
Im always paranoid the diff mounts are not 100% parallel and have friction so I wanted to brace them with tubes so when tight they are perfectly spaced.
Slight re-think, 2 braces at the top, the bottom will be plenty strong attached to the chassis. trimmed and lightened as much as possible and drilled all the holes.
thats what im talking about!
another test fit
made a simple servo mount, 4 rods.
